Help...Complicated 4-sub wiring problem...
Pimpdaddyq
Owner: Quicks Car Audio
ok i have a friend who has the Hifonics ZX1000 amp... he has 4 Fosgate 15" HE's and they are all 8 ohm subs... now wiring them all into parallel would be a 2 ohm load, yes... but is it possible to basically think of it as 2 subs and make it like a "Dual 8 ohm subs"? As if each set of subs is 2 subwoofers...wiring one sub to the other...so one subs - to the others + and then do they same for the other 2 subs and put the 2 together into a 4 ohm load? Amp pushes 1000w at 4 ohms bridged which is perfect for all 4...confusing? hell yes...please help thanks!
Pimpdaddyq
Pimpdaddyq
Clinton Iowa
johnecon2001
michigan born
    May 14, 2026
michigan born
    May 14, 2026
