Help choose my next setup:(4) 18's- Ported Clamshell or 4th order?
What should be my next setup ?
  • Total voters
    17
Millertime1028
Just want some opinions from you guys on what route I should go with my next setup for the Summer . I have 34 Cu/ft to work with . Tuning low . I Like the idea of a ported clamshell, fairly easy to design and build, will look pleasing to the eye -or- A 4th order bandpass. A bit harder to design but efficient if done properly. Just looking to get a tad bit louder then my current setup . Input and other suggestions are welcomed . Thanks guys
Hmm, yea thats what I was worried about , not having enough room to build a sufficient 4th order .. As for the degree of the clam it would have to be around 45 degrees in order to build a proper size port . I dont have that much height being that this is for a Jeep Cherokee . I will be doing some more measuring to see what else I can come up with .
Hmm ... See I would be able to do (3) 18's in a subs up/port back but this gives me issues with my amp situation . I would go with (4)15's but I would like to use the 18's that I already have . They are still fairly new . I wish I can do (4) 18's in a subs up / port back but I just dont have the length to do so in order to achieve the correct cu/ft . Im almost leaning towards building an extremely effecient 4th order for the (2) 18's I have at the moment or a Clam for (4) of them ..
Hmm ... See I would be able to do (3) 18's in a subs up/port back but this gives me issues with my amp situation . I would go with (4)15's but I would like to use the 18's that I already have . They are still fairly new . I wish I can do (4) 18's in a subs up / port back but I just dont have the length to do so in order to achieve the correct cu/ft . Im almost leaning towards building an extremely effecient 4th order for the (2) 18's I have at the moment ..
What kind of 18's are the 2 you have?
I think BL's are better suited for ported than 4th order.
I think you could get away with 4 18" BL's in 30 cubes at 30Hz with about 6000w.
The ports would not displace much if you used four 6"ers.
Millertime1028
Millertime1028
Long Island, New York
Millertime1028
