Help cant decide what to get l7s or pioneer premiers
Really don't give too flyin **** what you got to say I am typin on a **** iPhone I don't care bout my grammar you jus have no life so u sit on a computer all day jerkin off to gay **** an doin this bullshit get a ****** life ******
Calm down man....most of the members are intentionally assholes just to see if they can get you goin. If you have a huge trunk then maybe 2 Sundown SA-15's, Single DD 18 hell man theres so many combinations....The sundowns are cheaper and take a beating and get damn loud. Anyway, browse the sub section and im sure you will figure something out once you have a bit more knowledge on whats decent and such.
Thanks for the info I see tht now I looked thro the site I am jus tired of spend money on garbage systems I have blowin easy 3000 on em in the last 4 months
with your budget you should have no problem getting some decent subwoofers,as stated above just browse the forum for more info on what members here use.Good luck
Why is this the response every single time someone on here points out stupidity? You should just take what I said and try to educate yourself a little bit rather than going off on me for having a working brain.
"i GET BITCHZ ALL DAY YOU DONT NEED NO GRAMMER WHEN U GET BITCHZ FUCKN LOSR ON UR COMPTRR NO LIFE FOR USING SENTZES GO DIE BITTTTTTCCCH"
On 2kW, with $700-$1,000, you have a ton of options. Is that with your box included? What are the dimensions of the largest opening to your trunk, unless you plan on building the box inside? What's your electrical look like? Are you sure you're getting 2k out of that Hifonics? I take it you're just looking for all out SPL?
By the way, just typed this on my iPhone. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
I always thought that Apple just had a special sort of auto-correct app that turned whatever you typed into that sort of all caps purposely mis-spelling everything language.
OP. If you're not afraid to buy used there's some ******* woofers come up on here all the time for well within your budget. I would avoid 18" in a trunk, but a pair of 12's or 15's you might have room to make work. Make sure a proper box is in your budget.
Dono
Dono
Port
hispls
