help bass fading in and out
  • 4
JChap
i had my system installed by a professional. I have an Alpine INA-W910 in dash head unit with nav. all brand new equipment JL door speakers and 10" JL subwoofers. 400 watt 4 ch for the speakers and a 600 watt for the subs. system worked great for 6 months. then the level of bass started dropping randomly. the status lights on my amp did not change indicating any major problem with it. i took it in to the audio store and got another amp put in due to a high pitch whine coming from the amplifier itself. they said it indicated an internal power issue with the amp. my system was back working great for a couple months and now it is happening again. there is no high pitch whine this time. all connections are good and i have a steady 14 v of incoming power. the volume out of the speakers remains the same. just the subs dim out sometimes for an hour or more. they never cut out completely tho. any insight would be appreciated
What does "bass dropping down but not out" mean?
And that sounds like an interesting issue. I would think you've got a bad connection somewhere or have some voltage drop, but apparently you've checked over all the connections yourself, and have clean, sanded down grounds? And checked the voltage at the amp yourself and it's not dropping below 14v?
the bass still hits just not as hard. almost as if its lowered on some sort if protection device but my amp has leds to indicate overcurrent and overheating
yes i have checked all the connections that i physically can see and get to including grounds. with my meter on the amp the voltage doesnt budge from 14 v
Peculiar indeed... Hopefully some more experienced guys can get in and help. Your title is misleading and vague, it might help if you had something like "Help, bass fades in and out" or something a bit more descriptive. I think you can still edit the post.
i have checked the grounding. both grounds from my subs amp and the 4-ch are secured tightly together. so being that they are together i would assume if i had a ground issue it would cause issues with both correct?
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
Yeah I had torn one down and used my digital calipers to measure coil size ID & OD and winding height and spiders all had it written down and had...
That was something I was going to try also to remove some of the gasjet from the front
update: still don’t know what’s wrong, but Kicker customer service is great. easy back and forth via email and they are sending me a pair under...
JChap
JChap
Franklin, CT
JChap
