Arc 1000.2=Frequency Response - 20Hz ~20kHz
Signal Noise Ratio >98db
THD - .2% all channels driven
Input Sensitivity Low Level - 250mV ~ 2.5 V
Input Sensitivity Speaker Level - 500mV - 5V
Max. Power Output - 500 watts x 2 @1 ohm
Cont. Power Output - 240 watts x 2 into 4 ohms @
2-Ohm Stereo Output - 450 watts x 2 into 2 ohms @
Bridged Power - 900watts x 1 into 4 ohms @
Arc 1000V1=RMS @ 4 ohm 500rms
RMS @ 2 ohm 1000rms
RMS @ 1 ohm 1100rms
Crossover Variable 30Hm - 250Hz
Sub Sonic Filter 10Hz - 80Khz
DLS A6=Output power in 4 ohm 500 W
Output power in 2 ohm 870 W
Mono bridge mode 4 ohm N/A
Output power in 1 ohm 1200 W
Damping factor > 200
S/N ratio, A-weighted > 100 dB
Frequency range 10 Hz - 125 Hz
Input sensitivity 0,2 - 7 V
Audison SRX2S=OUTPUT POWER (RMS) @ 13.8 VDC; THD 1%:
- 2 ch (4 Ohms): 180W x 2
- 2 ch (2 Ohms): 300W x 2
- 1 ch (4 Ohms): 600W x 1
Here's my dilemma....my phoenix gold xenon 1200.1 suddenly went into protection mode and won't come out so I'm forced to start my journey to find an amp to drive my 2 Boston Acoustic G512's (2ohm) subs. These are my top choices at the moment and I would like to get everyone's advice on which they would choose. Price isn't the issue because they are all around the same price. Only difference is the Audison is brand new and I'm leaning a little bit more towards it both because its new and it I'll be running the subs in 4ohm so i'll need between 200 and 900 watts RMS. My one concern with the DLS (even though I know it's a beast) is the amperage it will draw.
RMS @ 2 ohm 1000rms
RMS @ 1 ohm 1100rms
