Help..4 channel stopped working
DetoxLS
I have been using a US acoustics amp for about a year. A few days ago i was listening to a cd and i heard static in the music that sounded like a radio fade out/in. I had a feeling it was the amp since it was a cd that was playing. Today I turned my car on and music played for about a minute and the amp cut out. All i heard was the sub which is wired on another amp. The power light on the amp is not lit, however the sub amp works, which has a remote wire running from the 4 channel.
Is the amp dead or maybe its a fuse? I pulled the two on the actual amp and they look good, along with all wires. Any suggestions?
Chris
take a DMM and check to see if your amps getting power from both the power wire and remote wire. then check to see if any of your speaker wires coming from the amp shorted out, you may have sent your amp into protection or even blown somethign inside.
DetoxLS
DetoxLS
South FL
dantheman8328
