tritonstudio
Hi all,
I am looking at these 2 amps to buy at the moment.
B/c of my Kappa series require about 100W-rms, that is why these 2 are looking great for the speakers. The AudioBahn is cost around $330, the RF is around $250. But if the audiobahn is built better quality , then I can go with it. One thing I like the AB is it has wider Frequency response range from 10hz-40k, which kind of match up w/ the kappas. If you have any thoughts & experience about these particular models, could you give me some thoughts.
Thanks a lot
AudioBahn A4125HCT Car Audio Amplifier:
Bass Boost With Bass Boost
Bridgable Bridgable
Power Output
RMS Power at 2 Ohms 250 W x 4
RMS Power at 4 Ohms 125 W x 4
Performance
Frequency Response 10 Hz - 40000 Hz
Low - Pass Frequency 30 Hz - 120 Hz
high - Pass Frequency 50 Hz - 750 Hz
Signal to Noise Ratio 100 dB
Bass Boost Frequency 40 Hz
Dimensions
Width 12 in.
Depth 19.81 in.
Height 3.69 in.
MOSFET amp Yes
Rockford Fosgate Power 851X Car Audio Amplifier:
Amplifier Type Multi Channels
bridgable Bridgable
Power Output
RMS Power at 2 Ohms 215 W x 4
RMS Power at 4 Ohms 110 W x 4
Performance
Frequency Response 20 Hz - 20000 Hz
Low - Pass Frequency 50 Hz - 250 Hz
High - Pass Frequency 50 Hz - 250 Hz
Bass Boost Frequency 45 Hz
THD at Rated RMS Power .05 %
Dimensions
Width 17.07 in.
Depth 9.85 in.
Height 2.38 in.
Other Features
Input Voltage 14.4 volt
MOSFET amp Yes
3 Way Ready Yes
Thanks a lot
Bridgable Bridgable
Power Output
Performance
Dimensions
Width 12 in.
Depth 19.81 in.
Height 3.69 in.
MOSFET amp Yes
bridgable Bridgable
Power Output
Performance
Dimensions
Width 17.07 in.
Depth 9.85 in.
Height 2.38 in.
Other Features
MOSFET amp Yes
3 Way Ready Yes
