Help, 3way load
614Emil
CarAudio.com Newbie
Can i bridge an 4 ch amp to 2ch and run focal kx3 3way on 4ohm load to each side?
Do they run on 4ohm when not bi-amped?
When bi-amped would the midbass get a 4 ohm load and the midrange and tweeter gets a 2ohm load since they are all 4 ohm?
Yes, using the x/o would give you a 4 ohm nom. impedance. Bridging a 4 ch is a good way to optimize power while having all the customization options through the x/o.
If you bi amp and run the mid/tweet parallel, again, yes, you should have a 2 ohm nom. load there.
Thx i will try that :)
worked wonderfully! drove 6 hours over the mountain after install/change, less distortion at lower volume and more fully sounded bass.
need more soundproofing for my doors now ^^
it was
4 x 125wrms @ 4 ohm
now:
2 x 365wrms @ 4 ohm
614Emil
CarAudio.com Newbie
614Emil
Norway
614Emil
