HELP!!! 2003 Toyota Camry Install Issues!!
Ok, here's some questions I have on installing rear 6x9s in my 2003 Toyota Camry. How do I? haha I can't pop off the grills and I have no idea on how to remove the rear panel to un-screw the factory 6x9s HELP! any info is appreciated! Another question...How do I "fish" the wire through the front seats for my headrest monitors? I already installed the monitors in the headrests but now I am having a problem fishing the wire down inside the seat to the bottom....Thanks for any help! Anybody that can offer me the right way to do this please email me ASAP at sean@avitable.com Thanks----Sean
I just popped them with some plastic pryers. As for the wire to the head rest I found it easier starting from the bottom up using a long cable tie, tape ur power, ground and video cable to it and fish it till the cable tie pokes out then pull from there. A hanger can also work or a cable claw.
Those rear grills should just pop off when pryed gently around the perimeter.
What I would do to snake the wires into the front seat is to use a metal coat hanger. First I'd straighten it out and form a hook on one end. I'd fish the hanger through the upholstery first from top to bottom, then tape the wire to the end of the hanger and fish it to the top.
MarineCarAudio
Altamonte Springs, FL
MarineCarAudio
