hei..
renier
Vivo BOoOM .i.(0_o).i.
Re: stiil the new L7s15 and the lanzar amp
hei!i've put the wirings of the sub parallel..it's loud as hell,but it's still bridge on the ampli..the ampli says that it's only brigdeable at 4ohm..my sub is a dual 4,so when i use series wires,i get 8ohms..and it sucks..at 2ohms, the body of my Suv shake and make a lot of noises caused by frictioning of something,i don't know..
i'm just waiting the ampli to protect,or 2 get faulty..
my ported box(used w/ a keicker es previously)can hold it..the mdf in front vibrate and make noises..so i can't enjoy the break in..
i don't know if i'm smelling the sub burning or the ampli or the mdf..
this morning, i've took a look and tried it again..
w/ the engine on..
my 2.4 farads lanzar capacitor at first was good..the current was always bet. 10.2 and 12.5..suddenly,it dropped at 8..7..6.. and it turned off by itself,turning off my whole system..what that means?
i looked at my alty,and it's only 45~?or 65~..
this is my dad's vehicle,that's why i can't make modifications by myself w/o telling him..
but the system is mine,i brought it..
can you help me again by tell me bout HTZ,how to calculate it and how to tune a box to the deepest frequencies?thanx
Setup-'05 S15L7 solo baric w/ a modified 6.6cu.ft ported box
-Lanzar HTG264 2 channel 2x600 Watt Mosfet Amp 2400W max
-Pioneer DEH-P4850MPH head unit
-2.4 Farads Lanzar Capacitor
-Lanzar vibe x8 crossover
-Clarion mids..
that's all..i still have my 15" kicker es,can i use it as a midsub?//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Extremely difficult to understand your post. I will try and answer the questions I can.
1. Your car is making noises when shaking because it's shaking. Not friction.
2. MDF on your box should not be vibrating. You need to throw away that box and get a proper one.
3. If you're smelling anything burning it's a bad sign. Figure out what it is. MDF does not spontaneously combust. It's most likely the equipment.
4. Disconnect the cap. Your alt is probably breaking from the stress.
5. You will need a new higher output alternator. A 65 amp will not power any amp well enough.
Teaching you to design a speaker box would be difficult enough. Especially with the language barrier. I suggest you grab a design from the sticky of box plans.
i smelled the port of the box and i don't know if it smelled like burning,but the smell was not so good..
my box was repaired because they put a division(port)and replaced the front face with a new one eliminating the round hole of the previous sub and the other two(3.5 pvc pipes)..that's why the front is so loose..they didn't sealed it properly..
i'm going to build a new one..i think 6-7 cu.ft..
i want to get a deep bass..
bout the cap,earlier the minimum reading was 10.2..and the normal 12.5..it didn't happen again..
replacing the alty cost me a lot..i don't know the requirement of the ampli for the alternator..the car's battery is brand new..
how to tune a port to htz?or lower?how can i measure it?
language barrier?
the box was built w/ mdf..but the 2nd shop told me it wasn't mdf,and this type of wood have a strange smell..and every time we open this box,we can see the corner of the box w/ plenty of this type of wood pulverized..
they took advantage of me..
yeah yeah..i talk like shit..if only i have guys like you here,who knows what to do first w/ the electrical and what system to buy..and how to get the best out of it..
there are good technicians here in the philippines,but not here in my province..
about a pair of ultra linear 10" 4ohm voice coil,if i parallel the wirings,will it get me 2ohms?
It would take me an hour to type up a tutorial on ported box design. Add the countless questions I would have to answer.
Use a box design in the sticky supplied by MoeLester.
That is why they are there. To help you.
they did!i didn't know they were going to open that..they used a hammer to took off the front..that's why now its a shit..here,if you don't have enough money,there is always a solution to that..that's why it happend..hahaha
oh,thanx man!i'm going to get a design,and going to measure the space at the back of my suv..they told me,the bigger box,the better..is that true?im going with 7cu.ft..i'll keep you updated..i'll post again soon..thanx anyway!
renier
renier
philippines
tRiGgEr
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
