headunit
  • 2
97dakota
lovin Belize
2,052
Missouri
Hey, I need some help. No one laugh, I am new at all of this stuff. I have an old sony headunit, an 800 watt explod amp and two jl 10WO subs in truck boxes. My headunit powers up but then no I only hear the bass from my subs. I have checked the wiring and it all seems to be tight, It comes on for short periods and then shuts off again. Is my headunit a piece of **** or what. any suggestions would be appreciated. thanks in advance.//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
I just bought new speakers and they work sometimes, it is almost like something is lose inside of the headunit or something, it will work and then when I go over a bump it shuts off, and sometimes I just hear nothing but from my subs. thanks for the help
what ^ said. amp gain setting info, test tones are at the very bottom...
413
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
It's a Volvo factory amp, so there's a custom wire harness between the head and amp.
6
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
8
995
97dakota
lovin Belize
97dakota
Missouri
97dakota
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
