Headunit Wiring Problem
  • 4
You can try to ground the RCA's to the deck. To see if that helps.
You could get an RCA jack at radio shack and test you lines with an MP3 player.
If you hear static with the mp3 its your RCA's.
If its clear return your deck and get an exchange or refund.
have you re-adjusted your gains on your amp? I don't know what your old radio was, but the Kenwood you have has 4v outs; a readjustment may be in order.
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
538
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Brad894
Brad894
Somewhere, AR
West
    May 31, 2024
    May 24, 2024
