Headunit wiring help
Lowflyin
Sit on my face, B*tch
I just irectly connect my wires to the stock ones. 2001 blazer btw. But anyways. Ou have everything done excePt the dash speakers and switched power. What color are these wires from the stock harness. I saw a page that said the switched was yellow but I connected it and hu didn't work.
here
LF Speaker +/- tan - gray +,- radio harness
RF Speaker +/- lt. green - dk. green +,- radio harness
LR Speaker +/- brown - yellow +,- radio harness
RR Speaker +/- dk. blue - lt. blue +,- radio harness
My switched wire must be dead or something cause it works when I hook it straight to a 12v source. And I just need to know the speaker wires for the dash sPeakers. Thanks for the others though
For Blazers and S-10s (including Bravada, Sonoma, Jimmy, Full-Size) the actual stereo wiring is as follows Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
Antenna Right Front
Front Speakers 4" x 6" Dash
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 6" x 9" Side Panels
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
your right - that is for newer years
For 2002 up blazers the wiring is as follows:
Radio 12v orange+radio harness
Radio Ground black-radio harness
Radio Ignition dk. green+radio harness
Radio Illumination gray (dimmer)+radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- tan - gray+,- radio harness
RF Speaker +/- lt. green - dk. green+,- radio harness
LR Speaker +/- brown - yellow+,- radio harness
RR Speaker +/- dk. blue - lt. blue+,- radio harness
I must just have a problem with my 12v switched then. Weird that I took out the factory hu and 10 mins later tried this new one and doesn't work. Well thanks
Lowflyin
Lowflyin
FU JOSE, PA
Lowflyin
