headunit remote wire question/help?
yne721
SWINE FLU!!!!
alright, so i've been having a problem with my system over the last month, there's a popping sound coming from my front stage. at first i thought maybe the amp or speaker wire was grounded out somewhere, but i checked everywhere and couldn't find anywhere. rerouted the wires just to make sure, and the noise continues. The noise is completely irregular. Sometimes it will be going at like 180 bpm, sometimes it will only go at like 15 bpm.
so my first question is, the noise only happens when my car is running. it does not make the noise when i just have my key in ACC. So could my remote wire be the culprit? since i couldn't find any grounding out, and i sanded all my amp grounds to make sure they were clean, could the wire i'm tapped into for my remote power be the problem?
and if so, could i just run the remote power wire straight to the battery with a toggle switch on the dash? Once i put a whole new electrical system(wiring and all) in my car, i'll hook it back up the way it's supposed to be, but i have so much old wire floating around behind my dash and near my fuse box, i don't really feel like fucking with any of the wires because i don't want to fuck something up...
Yep.
If you decide to go this route might I suggest a lit toggle rather than an unlit one as to hopefully prevent forgetting to disarm the amp when the car is off resulting in a dead battery overnight?
Yep.If you decide to go this route might I suggest a lit toggle rather than an unlit one as to hopefully prevent forgetting to disarm the amp when the car is off resulting in a dead battery overnight?
i was thinking about that, but since my car doesn't have any interior lights it'd be pretty easy to see if i left my headunit on.
on a side note, where have you been guy how are you?
yne721
SWINE FLU!!!!
yne721
Maui/Detroit
yne721
BP1Fanatic
BP1Fanatic
