Headunit Problem
fire919
Problem: My HU is causing my battery to drain(checked with a multimeter) Pioneer Premiere 600UB
Question: Can i connect the 12v constant wire and Acc wire together from my wiring harness to the Vehicle's 12v Acc wire? will that work/stop the problem?...and do i have to keep resetting my HU settings everytime i turn on car.
....any other suggestions?
It shouldn't be draining power, if it is, then you have either a weak battery or a problem with the HU, one needs to be replaced.
is it wired in correctly?
416
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
996
fire919
fire919
the bronx,NY
ellocojorge
    May 18, 2024
    May 18, 2024
