Headunit not remembering settings.
Crownvicon28s
God 1st
I got in my car the other day and realized that my music didn't sound right, and it wasn't because I dont have a substage. lol. I checked my settings on the headunit and they were set to the factory settings, so I changed them to where I normally have them. Then later that night they were back to the factory settings. WTF? IDK which wire is the memory wire on this deck or if thats even the problem. Help.
some times there is a fuse on the mem wire. check it and see if it's good
You know what I think this might be it. My headunit was saying that there was a connection missing. This will be the first thing I check tomorrow. Thanks. Headunit is a kenwood kvt-815dvd btw.
Checked all fuses and they were good. All the wiring looks to be correct. I guess something is wrong with the unit. It keeps the time and color scheme but drops all musical settings. Any other possibilities?
So it was keeping all the setting before but then it started to not remembering it? The wiring harness isn't frayed or loose anywhere? If so then yeah there's something wrong with the unit, probably a bad solder joint.
Thats what I figure. I will check everything again. thanks for the help.
Crownvicon28s
God 1st
Crownvicon28s
Spartanburg, SC
Rich B
