Head unit went out - replaced and still not working!
  • 4
LongThrow
My Kickers be swaggin'
I have a Kenwood kdc mp238 and all 4 door speakers stop working. Then a week later the headunit itself turned off randomly which playing music. I checked all fuses and they were good. I went to Walmart and bought a 70 dollar jvc. I usef the existing spliced factory to aftermarket wire harness, and hooked it up all correctly and this head unit isn't working!
Could it be a problem with my factory wiring? And how would I fix that?
A little more detail would be nice, I try to include as much in my questions.
You need to get a digital multimeter so you can test your harness wires and see where the problem is. If you want to make sure the new stereo works, put the yellow and red together and hook them up to the+of the battery. Take the black wire and hook it up to the -.
unhook your stock harness adapter and see if any of the connectors have burned.
so the wires connecting toy stock wire.harness will look "burnt"?
I guess I'll have to get a dmm and check and get back to you
Yes... If they are burnt then the connector is bad. Either way you can always connect the wires directly to the factory wires.
Also make sure 100% that you have connected your headunit correctly.
Meaning wired correctly.
Factory wiring > spliced to aftermarket harness> connected to head unit. all wires are spliced to the correct color coded wire.
If there any problems with the wiring (factory wiring) how would that be fixed?
196
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
494
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
632
I have a 06 grand Marquis. Looking at either Kenwood or Sony Apple play. Is it worth have a floating monitor? Pros and cons?
LongThrow
LongThrow
Springfield, MO
LongThrow
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
