head unit cuts out
  • 2
I need some help I have a pioneer deh-17 head unit it's about 8 years old I use it outdoors on trips it is hooked to a deep cycle battery power wire and acc are hooked to pos and ground is hooked to neg now my problem if I'm running it without an amp from the speaker wires on the back after about volume 18 it starts cutting out then if you go up more it will power off then back on and keep doing this til you turn it down but if it is hooked to an amp it works fine what could my problem be?
117
531
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
633
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
766
jonathanf
jonathanf
Caruthersville, Mo
maylar
    May 18, 2024
    May 16, 2024
