HD Radio HELP, ALpine Unit!
grizzly02
NJ
MY new Alpine HD-Radio goes in and out of an analog signal and never really stays true to the HD. I called Alpine and told them everythign is in an 05 Mazda. They asked me if it had a roof mount Antenna and said that the Blue wire from the HD unit has to be connected to the blue wire in the wire harness (radio harness) if thee is a lue wire in the harness, because the roof mount antenna needs to be energized? WTF does that mean, are roof mount antennas energized?
From http://en.wikipedia.org/wiki/Hd_radio
Most of the first generation HD Radio tuners have been noted as being very insensitive, making reception problematic. In hybrid mode, the HD Radio signal is 1/100th the power of a station's analog signal. Due to its relative weakness, the HD Radio signal will sometimes drop out and the receiver will revert to analog mode. This can be especially problematic in fringe areas, where the digital signal may frequently be lost. If the digital stream on the HD-2 channel is different than the analog broadcast (multicasting), then any time the digital signal fades out the radio effectively changes stations to whatever program is broadcast on the analog signal. While this is by design, and is part of the HD specification, it can be very annoying to the listener, who perceives the channel to have been randomly changed. In addition it has been noted that the analog section of some tuners displays poor reception capabilities compared to older non-digital models.[28]
Two ways to go about it. First, the easy way- Next, the budget but more involved way- On the second one, you buy the harness to install an...
Tex, if you have Sirius/XM, were you able to use your OEM antenna or did you have to install the one that comes with the kit? Good job on the...
28
4K
I have an XY Auto Android Radio. During day my phone connect and music works, and I can use steering wheel to control volume. That’s it though...
grizzly02
grizzly02
NJ
ToxicBanana
    May 31, 2024
    May 24, 2024
