Hate the sound of my Atlas
SirSyko
Delusional Psychotic
Today I hooked my 12" AA Atlas up to my Rythmik Audio plate amp. The amp is rated at 150 watts RMS @4ohms. The sub is in a 1.35 sealed enclosure with a double baffle and a couple braces inside.
It does not sound good at all. What is the problem? It sounds so boomy, and doesnt get low at all. Playing with the tones, you can only begin to hear it at 25-30hz. The crossover on the plate amp is turned all the way down to 40hz but the sub still plays much much higher than that. Also, on Ascendant's website, looks like Ill need a good 4 cubes sealed to get anything close to what I want. Will it make that huge of a difference?
I then hooked the amp up back to my sub which I originally bought it for (RE8) and it didnt even sound close to the Atlas, quite opposite actually.
What should I do? New HT sub?
Brand new high excursion subs can sound boomy in small sealed enclosures when new, especially with only 150 watts RMS to power it
Switching to a much larger sealed enclosure or a ported enclosure will make a huge difference in the sound.
when i hooked my atlas 15s up in my car with 3cubes sealed, they sucked. Ported them, and made a world of difference. Have even been debating going back to an atlas instead of my avalanche.
I bought the sub used, but it looked brand spankin new when I got it.
The 150 watt plate amp I have is for my room. For the Atlas I plan to get a 380 watt amp with a 24db octave roll off http://rythmikaudio.com/nonservo_product.htm
Or the dayton http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=300-806
Which one should I choose?
And about the box size, I might give Chad a call then.
get the RA amp. you won't notice a difference if you have 500 watts instead of having 350 watts. plus the RA one is cheaper.
SirSyko
SirSyko
Vancouver, WA
adio
