ecbmxer
I've done my install and I have a really bad case of engine whine. I am running a Pioneer DEH-P8MP HU and a DLS A5 amp powering a DLS MS6 component set up front and 2 JL 10W3V2 subs. I have a 2005 Nissan Titan king cab truck. I have the amp grounded on an existing ground point behind the rear seat. The power wire runs on the passenger side and the RCAs on the drivers. I have the HU grounded to this big metal structure in the dash, which goes right to the chassis. The whine goes away when I unplug my component set RCAs. THe one thing I am thinking is that I have the RCAs and power and ground wire kinda jumbled up directly below the amp so that I can have slack to pull it up and adjust things. Would this small amount of contact create noise? Also, the RCAs do cross the ground wire for 6-12" or so right next to the amp. Would this do anything? My next step is to try to separate these wires even more and see if I can improve the ground any. If that doesn't work, I'll try to reground the HU. If that doesn't work, should I run a wire between the HU ground point and the amp ground point? What else can I try? I know about the Pioneer HU stuff, but I really hope that a high end HU like this is free of noise. I really like the HU alot and don't want to get rid of it unless its a total last resort. Any help is really appriciated!
