Harness requirements?
Chev15
I am wanting to install a after market amplifier to my 2004 Chevrolet silverado 1500 extended cab with onstar and standard bose system factory head unit. I'm not sure how though. Is there any kind of harness(s) that i can use to keep the factory head unit, onstar, bose system (factory amp), and warning chimes? And if there is, how do i do it? I'm planning to hook up a sub to the amp if i can get it hooked up right and keep everything working! Thanks
You can go the crappy cheap way and buy a simple hi lo converter for $15 bucks or you can purchase something like audiocontrols LC6i
why not just go with an aftermarket radio and get the correct harness that retains Onstar and warning chimes. you'll spend about $100 on a quality LOC and the GMOS harness is about the same price and you can get a HU with all the features your current OEM unit doesn't have.
Do you think a NVX XPLOC4 output converter would do the trick, and fulfill my needs? Also, my sub is 400 watts rms and the amp 450 rms.
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
926
I would make a call, or send like Crutchfield or Sonic Electronix an Email or even Chat with them and see if they can help you get the correct...
If I was in your situation, I would experiment with the wring for a day or two. If that didn't work, I would purchase an external amplifier. Run...
985
So is the radio harness spliced direct to the OEM harness? There is no adapter harness?
Chev15
Chev15
Roopville, Ga
Chev15
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
