Had a little accident with the Denali last night...
easy fix ...take ur bumper off. tape the cracked section in place from the outside, lightly grind off the paint sealer primer down to bare fiberglass on the back side about 3" inches from the crack on each side , gring a lil deeper close to the crack , use fiberglass matting and resin on it like a patch. do three layers of matting resin between each. un tape the outside grind off the paint, v the crack out a lil use a few layers of matting and resin same process as the back. sand it smooth, coat it with some bondo prime paint. you can reverse mask right along the body line and paint just that lower section, lightly buff the edge of the clear and itll look good as new
this... for the most part
go after the gas station for putting a hardly visible pole in the middle of nowhere.
Well I can pretty much guarantee it was by a gas pump or sidewalk just like at any other gas station. So if it wasn't there, he may have hit a gas pump or a pedestrian. Either way, someone's dead.
Most of them I see are 4' tall and 1' wide and painted a bright *** yellow so this may prove difficult.
maybe I'm giving the OP too much credit then //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
back-up camera coming?
You bet it is
taht breaks my heart to see:crap:those are my favorite trucks, so are you gona replace the whole rocker panel or cut and make a filler piece since its fiberglass?
ha ha ha yeah everone loves the Denali's
Wasn't in the middle of no where, was near the pump and painted white. To get out of the parking space I had to reverse up an incline so the *** end of the truck was high in the air which is why I couldn't see it
My ex wife used to do that, LOL.
I've seen people do it especially when I used to pump gas back in high school. I always laughed at them. Payback is a ***** ha ha ha
ah, it was an honest mistake. same thing happened to my buddy. he just bought a brand new f-150....first full size truck for him. he was backing up to turn around at his work and BAM, went right into a small pole. did the same exact thing, except he never fixed his, lmao.
NeverEnuffBass
Got Bass?
NeverEnuffBass
Greenwich, CT
intence
