H/O Alternator
cbrpilotguy
I have an MA Audio 4400 watt amp installed in my car. This shop told me that im not getting the full 4400 out of it because i dont have enough power, which i knew already. Then he tells me that in order to get the 4400, i need a 17 volt alternator cause the amp needs 17 volts. Does this sound right. and if so, where the heck do i find a 17 volt alternator?
itsgonna be tough gettin 17v outa your lectrical system... MA rated that amp at 17v for a reason, so people can buy it.
the amp doesnt NEED 17v it just wont do its rated power below that
Well i wanna get the full power out of it, so what do i need to do to get it up to 17v?
You will need to run a seperate charging setup for the 17v. You car accesories will fry on 17v. You will have to run dual batteries and dual alternators. Have fun with that. I seriously suggest you stick with the 12v charging setup.
first off do you realize how loud a true 4400 watts is going to be? have you done any electrical system upgrades at all? do you realize the strain a 4400 watt amp will pose? what subs are you powering? what ohm load?
cbrpilotguy
cbrpilotguy
Detroit, MI
Johnny Drama
