To start off, I have a 2 subwoofers with a 600 watt amp and by researching on the internet I eventually figured out what to do and how to do it. That was about 2 years ago and now for christmas I got 2 15's RE SE subwoofers. Yay!
Some Specs:
Dual 2 ohm Voice Coils
1200 watts peak output
600 RMS
Qes: .55
Qms: 4.3
Qts: .49
Free Air Resonance -Fs: 22 Hz
Vas: 209 liters
Overall Diameter - 15.65"
Bolt Hole Circle - 14.85"
One-Way, Linear Excursion -Xmax: 18 mm
Efficiency - 87.1 dB SPL @ 1w/m
DC Resistance -Re: 2.8 ohm
Mounting Depth - 7.75"
Dual Composite 2-piece Cone
Tork-Tite Terminal
3" 4-layer Aluminum Voice Coil
FEA Optimized Motor Structure
Triple Stack Maganets
I understand I need a new amp. I might have an idea but I what to make sure it would be the right choice with you guys. Also, I probably need new wiring from reading previous post, but what would I need to rewire? Also anyother issues I might need to know before going head first into this project?
I guess I'm just looking for someone to give me a little push forward. I can't wait to start on my box soon before the snow gets too bad to work outside. Thank you so much for listening.
Some Specs:
600 RMS
Qes: .55
Qms: 4.3
Qts: .49
Vas: 209 liters
Tork-Tite Terminal
