mr.michael
BOB SAGGET!
the amps ground goes to the frame iirc? or does it go to the batts negative then frame? spank you. post boobies if youd like
stop posting stupid fucking threads and use the search button asshatthe amps ground goes to the frame iirc? or does it go to the batts negative then frame? spank you. post boobies if youd like
stfu and gtfo feggotstop posting stupid fucking threads and use the search button asshat
thnx for the bump and the attempt to help *** but you are an idiot and couldnt help if you threw yourself off a bridge. you are failure attempt of a human.everyone knows the ground for the amp goes to the battery positive //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Honestly though, if you don't know how to ground an amplifier you have NO business installing ANYTHING. That should have been the first thing you learned...and in most cases if you don't have someone knowledgeable to teach you, you can USE THE SEARCH BUTTON TO FIND THE INFORMATION YOU NEEDthnx for the bump and the attempt to help *** but you are an idiot and couldnt help if you threw yourself off a bridge. you are failure attempt of a human.
yes.Honestly though, if you don't know how to ground an amplifier you have NO business installing ANYTHING. That should have been the first thing you learned...and in most cases if you don't have someone knowledgeable to teach you, you can USE THE SEARCH BUTTON TO FIND THE INFORMATION YOU NEED
you seriously can get a life and try saying shit like that to peoples faces to see what happens. your a deuchbag get out my thread. it was a quick question to remind me of what the real answer was. if i tried to search id probly just find a buncha BS threads with felchin feggots like you dumping on audio question threads. this IS an audio site whether you can accept that or not. why you gotta be an idiot? you werent born with the knowledge of how to hook up an amp? i already knew i just needed to be reminded. why dont oyu go over and bump my other thread ***Honestly though, if you don't know how to ground an amplifier you have NO business installing ANYTHING. That should have been the first thing you learned...and in most cases if you don't have someone knowledgeable to teach you, you can USE THE SEARCH BUTTON TO FIND THE INFORMATION YOU NEED
you mad?you seriously can get a life and try saying shit like that to peoples faces to see what happens. your a deuchbag get out my thread. it was a quick question to remind me of what the real answer was. if i tried to search id probly just find a buncha BS threads with felchin feggots like you dumping on audio question threads. this IS an audio site whether you can accept that or not. why you gotta be an idiot? you werent born with the knowledge of how to hook up an amp? i already knew i just needed to be reminded. why dont oyu go over and bump my other thread ***
bump my other thread ***. or continue to be a waste. maybe go take a shower you grimey mother****eryou mad?
lol im older than you idiot.yes.
kid, you've been here since '08 and still don't know how to fcuking hook up an amp? GG+1. quit while you're at it.
