The longer a wire, the more resistance it has. When a current flows through a resistance, a voltage drop is produced. Because of this, the ground reference at the amplifier's circuit board is no longer the same as that at the chassis of the vehicle. This ground potential differential can lead to noise and improper operation of the amp. it is best to keep you ground as short as possible. not saying it cant be long, but the longer, the bigger the wire, the more money. if you can, get it as short as possible
Yet again, you are an imbicile.
thanks alot
i was talking about the battery under your hood.
i was just wondering, good info.
No. No it's not good info, he is WRONG.
what advice can you give??
bood idea or bad to hook up the ground to battery under your hood.
I think blackbonnie has a good point, that why whan you buy a grounding kit it only comes with 5 feet of ground wire.
Personally, I think it is a waste of wire unless you are trying for that extra .1dB
Grounding to the actual battery itself is even better than ground to the chassis. It gives you a DIRECT path to the battery (and alternator if the big3 is completed).
Unlike when you ground to the chassis, when the reference point of ground in the front... and ground in the rear can differ. There is MUCH more resistance in the chassis itself... current has to travel through the entire body of the vehicle... through shoddy welds... and sometimes piant/undercoat.
Grounding to the battery gives you the EXACT same reference point of ground as the battery itself (power source) AND alternator (again, if you've completed the big three).
The resistance of the wire itself is neglible, considering it has less resistance than the entirely different reference point of ground to the chassis in the rear.
Why do you think dBDrag competitors run dozens of runs of positive AND negative to the rear of their vehicle? You think they would do all the negatives if they could just get the equivalent by running a dozen chassis grounds to some point on the body of the car itself in the rear?
This is why I hate r-tards. Especially giving advice.
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
nG
