ground
upnover
i'm fixing to run new 0 gauge power wire, and was thinking of using the old 4 gauge power wire as a ground(off the -batt. terminal), and using my old dist block as a ground dist block, would this be better than grounding off the body. i'm running 3 amps, around 1200 watts. thanks
si
if you run 0 gauge to all 3 amps, you should run 0 gauge as your ground from the amps, and ground them to the body with as short of a ground wire as possible and in different places... supposively if you run a ground all the way back to the -batt terminal, you can fry your amps and all your electrical system
Originally posted by pimpedoutblazer if you run 0 gauge to all 3 amps, you should run 0 gauge as your ground from the amps, and ground them to the body with as short of a ground wire as possible and in different places... supposively if you run a ground all the way back to the -batt terminal, you can fry your amps and all your electrical system
put your grounds at least 2-3 feet away from your amps.
oh yea nd blazer, 'supposively' is not a word :p //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
supposedly:D. And the ground wire should always be at least the same if not bigger gauge wire than the power wire.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Originally posted by pimpedoutblazer thats why i failed english....
heh. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
the guy i bought the amps from said i'd need an alternator, be ruined his, my question is would i benefit any i went with one of the 16 volt batteries, or are they going to require a aftermarket alternator to run anyway.
not sure of the output, it's a 3/4 ton 'burban with a big block, and the towing pkg., i know when i ordered my dodge with the towing pkg it included a higher output alt. guess i'll have to check it the truck had a huge system in it before i bought it but it all got stolen, hoping the alt is aftermkt, but it looks factory
upnover
upnover
tulsa, ok
mgaidica
