Ground wire????
I agree, running it back to the engine bay will cut down on the potential for voltage drops through the chassis, but I would connect to Alt ground as opposed to battery. Will it make a difference, maybe not but there is the potential that the capacitance of the battery would introduce noise if connected directly to the battery terminal.
your front battery is not a ground its grounded to the frame which can be done from the trunk get a good ground to the frame in the back and its the same thing with less money spent on wire
doesnt technically matter its more of what you connect it to i prefer just popping a hole in the trunk and going into the frame under car rather than another 0guage run up front
Thanks for all ur input. I thought the shorter the gnd the less resistance u have. But okay.
good quality wire has a very low resistance through out the size ranges,from 8 awg all the way through 0,0/1 awg.i use 0/1 awg for my amp and mine is grounded in the trunk to the frame and to the 4 batts in my trunk my grounds are only 15" long
Duh. You ground it to the ground.
You're welcome.
It’s nice having a test bench. That one is nice and clean! I don’t have pics of mine but mine is built all out of wood with carpet top and all...
16
I agree…not a very good install. Hopefully you didn’t pay much (hopefully it was free). Get your DMM (or find someone who has one) and find a...
Thanks everyone, I connected the yellow wire from the sub to a blue wire on my pioneer head unit, which is for remote control apparently since it...
  • Locked
Thanks for the quick rep and it was great chatting w/ you. Good luck w/ what we discussed. It rare but sometimes I stumble across odd and ends...
18
Groundpounder22
bassbeast22
Groundpounder22
Dearbornheights,mi
Groundpounder22
RedRyder18
    May 11, 2024
RedRyder18
    May 11, 2024
