Ground wire????
I agree, running it back to the engine bay will cut down on the potential for voltage drops through the chassis, but I would connect to Alt ground as opposed to battery. Will it make a difference, maybe not but there is the potential that the capacitance of the battery would introduce noise if connected directly to the battery terminal.
your front battery is not a ground its grounded to the frame which can be done from the trunk get a good ground to the frame in the back and its the same thing with less money spent on wire
Thanks for all ur input. I thought the shorter the gnd the less resistance u have. But okay.
good quality wire has a very low resistance through out the size ranges,from 8 awg all the way through 0,0/1 awg.i use 0/1 awg for my amp and mine is grounded in the trunk to the frame and to the 4 batts in my trunk my grounds are only 15" long
Duh. You ground it to the ground.
You're welcome.
Groundpounder22
bassbeast22
Groundpounder22
Dearbornheights,mi
Groundpounder22
