Ground to Amp???
All_Logix
Formerly CivicGTi
So I have had a few people mention to me that I might can help my alt whine if I run a wire from the chassis of my HU to the chassis on the amplifier...I am wondering if this will work because I have the pwr and RCA on opposite ends of the car, I have the HU grounded to the car chassis, and I have good grounds for the amps and still have whine, even tried different HU...if I plug ipod into amp through the RCA it goes away and if the RCAs aren't plugged into the amp there is no whine...
You have whats basically a "ground loop" this caused by the difference in electrical potential at different grounding points in your audio system. (All the grounds in a system should ideally be at "0" potential.) A ground loop typically adds a loud low-frequency hum or buzz as soon as you plug in any of various audio components, including Amp/amps, EQ's, H/U, Stackers etc. The buzz/hum is a byproduct of the multiple power supplys, power cables and a ground voltage differential within your system and its network of interconnecting cables.
A few checks...
Make sure the amplifiers have a good audio ground reference. In order for the amps to function properly, the audio ground must be referenced to chassis ground at the source unit. If it is not, the amplifier could oscillate. To check for a good ground reference, take a volt-ohm meter (VOM) and measure the resistance between the chassis of the radio and the shield of the RCA line level outputs of the radio. This reading should indicate a direct short. If this is not the case, grounding the shield of the RCA line level outputs to the chassis of the radio will probably be necessary. Keep amplifier power ground wires as short as possible. The longer a wire, the more resistance it has. When a current flows through a resistance, a voltage drop is produced. Because of this, the ground reference at the amplifier's circuit board is no longer the same as that at the chassis of the vehicle. This ground potential differential can lead to noise and improper operation of the amp. This is the same between amps and other stereo components. All should be nearly the same resistance back to the negitive terminal (yes I know - not easy to obtain).
Yeah I know it's a groundloop... and I have run the RCA away from power...and it a Kenwood bt948hd, the only thing I haven't tried is what I stated above running a wire to the chassis on each and I haven't wrapped bare wire around the RCA terminals on the HU... It's kind of a stranage GL because I can put my gains down and it is still decently loud and it goes away...but I don't believe it's the full potential of the amp...has anyone else had to wrap wire around RCA terminals to ground them on Kenwoods?
in would try wrapping bare wire around the rca'son the radio and grounding that to the chassis of the radio. also running a separate ground for the head unit to the chassis and not grounding it to the harness anymore.
i had this same issue just yesterday, it was so bad even when i turned my key off, my sub would thump really loud. did the above, and its completely perfect now.
also where are you located in Texas?
Kenwood doesn't have the same situation as Pioneer. i would just measure continuity between the RCA shield and HU chassis before i started grounding outputs. Applying a fix for Pioneer on other makes could result in damage.
simply use your DMM to measure resistance between RCA shields and chassis. if you get less than .5 ohms, then no need to wrap wire around the shield. measure before action. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
CivicGti did you even read what I wrote?... Also check the resistance from the amps earths and from the CD player's earth to the negitive terminal. Having good earths does not mean you dont have a ground loop.
All_Logix
Formerly CivicGTi
All_Logix
Texas
reallyxxxxloud
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
