adulbrich
Olive oil un-virginer
I don't want to ground my battery bank to the frame. I'd rather just run a deticated ground up to the front.For every ground you steal off the engine, you have to add one from the engine to the frame.
Your engine is not in itself a grounding point, your basically using it as a terminal block if going to engine then to frame.
For a separated alternator the best way is this;
Alternator is bolted to engine, that's a ground, now add a ground from engine block to frame to account for that. You can ground your battery bank to the frame in the rear, or run yours grounds all the way to the front. Keep in mind, if you run 2 x runs from back bank to your engine, that is another 2 runs you have to go from engine block to frame.
I think everyone in here is talking around each other and is getting confused.
I like one big central grounding location in the rear for the bank. Do big 3 up front. That's my preference.
I don't need to add more engine to frame ground if I'm not grounding more things to the frame.
If I grounded the amp and battery bank to the frame, yes I would need more engine to frame grounds. Since I didn't, I do not.
My battery bank in the back is not connected to any batteries up front
