Green Light on JBL 600.1?
Daniel
Caraudio.com
863
SFLA
Ok, i just installed my jbl 600.1 to two blaupunkt pcwi1200 subs. I am pretty sure that i installed them into parallel position. When i turn the power on the green light flashes and it says that the green light indicated an overheated amp, but it turned on maybe 2 seconds after the power, so it cant be overheated! It says to make sure the impendance is fit for the amp, and it is stable at 2OHM so i am wondering why it is always on? I wired it like this, (SUBS) Negative to Negative, and Positive to Positive, I used 16 guage wire which was like two wires connected, i just cut them in half to connect the two negatives and positives, and the stripped the double wire at the ends and spun them together so it was like one and put it into the amp, is that wrong?
Please Help!
Well I sudgest upping your speaker wire size and going back to check all your power connections, make sure the ground is especialy good, make it very clean, the JBL like their ground to be clean.
You would have a problem if the green light wasn't on. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
hehehe thats the first thing that went through my mind when i read that the green light was on...
usually (not always, but MOST of teh time) Green = Good.....
lol.
it jsut makes sense....
i read the manual and it says No Power ( GREEN LED is on) it says amp is overheated and to check the impendance
are your subs dvc or svc??if they are 4ohm dvc subs wiring them in paralell produces a one ohm load...which is not healty for most amps....if they are svc then u are ok...
Ok, it does say that in the owners manual, but it's in the troubleshooting section. What it's saying is that the green light is on (indicating that the amp has power) and yet there is no sound the amp might be overheated. This has nothing to do with your situation other than your power light (green) is going on and off or flashing. You need to recheck your power, ground, and check to make shure your remote signal is good. I bet it's either the ground or remote //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
I would assume they are pretty accurate as long as they are directly tied into the clip circuit on the amp. Having said that, the signal traveling...
712
I am not well versed in box design, so I do not know outcomes based on over/under sizing. The one thing I do know is that too big of a port will...
673
Big subs have heavy cones. Heavy cones plus high power requires solid anchoring and solid enclosures. Most people don't anchor their boxes to the...
16
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
Daniel
Caraudio.com
Daniel
SFLA
Daniel
    May 12, 2024
Brendon Jenness
    May 11, 2024
