Ok, i just installed my jbl 600.1 to two blaupunkt pcwi1200 subs. I am pretty sure that i installed them into parallel position. When i turn the power on the green light flashes and it says that the green light indicated an overheated amp, but it turned on maybe 2 seconds after the power, so it cant be overheated! It says to make sure the impendance is fit for the amp, and it is stable at 2OHM so i am wondering why it is always on? I wired it like this, (SUBS) Negative to Negative, and Positive to Positive, I used 16 guage wire which was like two wires connected, i just cut them in half to connect the two negatives and positives, and the stripped the double wire at the ends and spun them together so it was like one and put it into the amp, is that wrong?
Please Help!
Please Help!
