Great Info on Gain/phase matching and why strapping ***** donkey balls
Wow, nice find Jeff. A little hard to understand sometimes due to accent and background noise but def informative and like how he demo's also. Explains things clearly. We need him on this forum lol
my whole car audio life has been a lie I wonder how many deebeez i've lost over the years. I'm trying to figure out how to do 4 D1 subs in series with this method... pretty sure this wont work but idk.... hopefully he responds to the comments.
So if your amps don’t have a phase knob, then i’m guessing you’re out of luck?
yup. best you could do is power match, you'll still be losing out several tenths of a db and several dbs where you might have cancellation. My buddy just rewired his amps and said his overall loudness improved slightly audibly, havent metered yet, but he said his 55+ hz response improved along with his subs reaching to 22 hz vs 24. Overall said the bass sounds a lot more cleaner.
I really want to do my setup ugggh.
Now I know why some amps have phase knobs...often wondered what they were for. Pretty handy to have, esp if one is running same exact amps as the guy said.
yup. best you could do is power match, you'll still be losing out several tenths of a db and several dbs where you might have cancellation. My buddy just rewired his amps and said his overall loudness improved a slightly audibly, havent metered yet, but he said his 55+ hz response improved along with his subs reaching to 22 hz vs 24. Overall said the bass sounds a lot more cleaner.
Your set up would be a perfect example....but dat rewiring doe! I know...can be a pita.
From the way the diagram looks in the vid, all the + go with the + on each side and same for -. On your diagram it looks like 2 of them are flipped on each side. Even tho his example is D4 and yours is D1 but the wiring should be the same shouldn’t it? Or were you trying to wire it even lower ohm load?
If i did it the same as he did, i'll be at a quarter ohm load.
Run it!! Lol **** hope that guy replies. This is like ground breaking news for anyone running multiple amps. Everyone competing or trying to get louder should be doing this. We need all configurations of this method laid out for everyone to see. Big game changer.
I think this has been done before and not something new.....but how many people actually follow this??!! I knew someone long ago that ran 2 DD 9515's, 1 set of coils per amp.
Yeah, these are listed as 3ohms nominal and that is why you see the 2.7ohm rating (where they can drop to). There are a number of things wrong...
885
i would recommend placing an amplifier on these to serve any justice at all https://www.polkaudio.com/en/product/mm1-series/mm6502...
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
547
I have a 06 grand Marquis. Looking at either Kenwood or Sony Apple play. Is it worth have a floating monitor? Pros and cons?
Jeffdachef
Gunz That Turn on Nunz
Jeffdachef
South Coast Metro, CA
Papermaker85
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
