jimmyjames1700
Hey guys, I figured I would share some teaser picks of one of our big installs going on right now. I will post more picks and explain the vitals of the vehicle/system soon.
Dynamat Xtreme in the doors. All four doors were deadened inside and out. All in all there is over 60 square feet of Dynamat installed so far. Front doors are receiving a pair of XR650-Csi's and the rears are being fitted with JL Coaxials.
Here is a pic of the box in progress. There will be 2 T215D4's inverted mounted up top. On the front angled part there will be a T20001BD and a T8004. Much more body filler will be added, and much more sanding will be done before the interior matching vinyl is applied. We will be adding some cool accent pieces and badges machined out of brushed aluminum and adding LED's.
Back of box before body filler is applied. If you look close, you can see holes cut for the 4 ports that are venting the box. Unfortunately, space was at a premium so we had to design the box a little smaller and tune a few Hz higher than we would have liked. But the customer wanted loud, so we will make sure that happens. Anyways, the box will be 5.25ft^3 net after displacement and tuned to 40Hz, more for SPL purposes than anything. Also, we decided to use round ports to easily change tuning for competitions or otherwise. Notice the spool of Stinger Expert 0/1 AWG wire.
After we are done with the install, the Jeep is being sent for custom paint and receiving 22" rims. Check back for more picks of the AVN/Headrest Screens/Stinger HO alternator/25Farad cap.....etc as they are installed.
