Graduation Gift Car Audio Setup For my Son
He's got an 04 Blazer Xtreme. Im planning on doing everything needed in order to get the sub to run where it needs to be, i know he'll put his money he had saved for buying the sub and amp towards door speakers ect so thats all him. And for "the big 3", are there any suggestions on what would be the best kit to buy? As stated above, im pretty clueless to the car audio world
You don't have to be inclined to the mobile audio world, just handy and know your way around a car.
You don't have to buy a big 3 kit. If you search around and source all the pieces you'll save a little money.
I used oversize 1/0 welding cable. Much cheaper than the oversized car audio brands.
you can use the same cable to run his amps too. So if hes plannning to run 2 amps, mind as well pre-wire everything for 2 amps. That means you will need a distribution block with fuses, split to two 4awg cables.
No svc amp I. Stock. For 5-6 weeks. Hate to tell you just ordered one for a customer should be a decent set tho. So you'll need a big 3 kit and good amp kit 0gauge. A custom box and front speakers. Deck and possibly a miss and highs amp
sq 2200 would power that sub nice. plus its not as expensive as the scv. xs battery good choice. big 3 you can scrounge up the wiring on your own. amazon, knukoncepts 0 gauge OFC. you are going to need fuses also. ANL fuse holder too.
Ok, So i need the following:Sundown Zv4 18 Sub
SCV2000w amp
XS Battery
Big 3 upgrade kit (any recomendations?)
Anything else that i would need?
Hit up mylows10 on here and get a Big 3 kit from him. Other than that you're the ******* man.
Does he already have the power wire, ground for the amp, and rcas?
Bassinglsksls
Long Beach Rhode Island
Maky
