got robbed... little help?
audiomortis
So, my car was broken into, and my stereo stolen. Not the first time. I've decided to leave the hole in the dash, get 4 chan amp for my 5.25's and my 4x6's, and run a portable mp3 player.
I don't know much about car audio amps. I know a little about amps in general, as I do PA and stuff, but I don't know most of these companies. I've been reading forums for about a week now, and I've got some questions...
1. Do different amps have different colloration? I like warm amps (I would run tube if I could afford to, or maybe my 1979 CerwinVega). Is one amp warmer and less digital sounding than the other, or is this a situation where a preamp will make all the difference?
2. I'm looking for about 60-80wX4 in the $200 range, and right now I'm looking at Phoenix Tantrum or maybe Soundstream VGA... are these good options? Is there something else I should look at?
3. With the types of amps i'm describing, will I need a cap or anything else to wire this properly?
4. Also, what are some good preamp/eq's on the market? I'm on a tight budget, but I may be able to make this happen.
Any help would be apreciated.
thanks,
joe
am I asking a question with no answer or just a stupid question? I've posted these kind of questions in a couple audio forums, and I just get ignored.
I would like to learn more about what my options are here.
1. Tube amps= warm. Normal amps= not warm.
There are not alot of Tube car audio amps, and the ones that are tube arent cheap
2. Those amps are fine.
3. Caps= no-no, there just a bandaid to a poorly made system
4. search ebay...see what you like then ask if its good
audiomortis
audiomortis
Oakland, CA
reed8857
michigan born
    May 14, 2026
michigan born
    May 14, 2026
