Got My SX18 Finally... PIX!
RE shoulda made their subs with push terminals and woven in tinsel leads
I would be bummed if my xxx's had come with push terminals, rather than the set-screw type they actually have. And, woven tinsel leads are not the end-all fix some people make them out to be. I prefer subs that don't use them personally, as there are better ways of fixing 'lead slap' than weaving a heavy, non-fexible wire into your moving suspension parts. *shrug*
lol, man that tiny motor on that big sub, y RE y? i juss dont get it. use the same motor for all size subs? i mean wtf. but its an 18'' who cares, shake sumthin;)
Uhm, last I checked the vast majority of sub manufacturers use the same size motor for all driver sizes. //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif Are you suggesting the old myth of larger cones are slower/sloppier is true? If not, what's your point? Looks alone?
I haven't been around much lately, but I see you are still at the same game of bashing RE every chance you get, even when you make zero sense doing it.
Cheers.
I got 2:eek:
i'd prolly be better off wt 1, i dont think i got enough space:(
such as? cuz the felt backing the put on the cone sure doesnt help
Is it a perfect fix? Nope. Its still a better fix than woven imo, for the reasons Ive stated before (in this thread or the other one).
I believe you mentioned broken tinsel leads in the other thread also, this comes from over excursion usually, not from 'slap'. A woven lead suffers from this same possible problem. *shrug*
Either way, its two different schools of thought. You suggested not weaving the tinsel leads is an obvious sign of less performance and/or build quality, this is simply not the case. Woven has its advantages, I don't think anyone is arguing that, but its certainly not the only 'right' way to do it.
MyKuL
18 Inches of Pleasure
MyKuL
Georgia
60_cent
michigan born
    May 14, 2026
michigan born
    May 14, 2026
