Got my Hertz components in...active help
i have a graph in the manual ill scan if needed, cant do too much on this slow comp at work
got the amp in today for them, does 133x4@4ohms on the birth sheet
cant say how much i paid:emb:
My first question is way you guys want to run you tweeters that you? Just a question for now.
I know the reason most do is because the midrange/midbass they choose can not be ran very high cleanly. But man it's a ton of mid to high midrange at 1.8khz and to my ears it just seems to thin out voices, i mean you loose some fullness to the sound.
bamaboy, man you have some amazing drivers there, as a person who has built many active system, be very careful with the tweeter setting check once and then check again before firing the system up. You can fry them very fast. Man good luck with then system any help I can offer i would be glad to. You also have a PM.
thanks man, im gonna try and take it easy on them, whats the lowest they should be ran? 1.8khz? i can do pretty much any frequency at either 12 or 24db att.
its all controlled through palm pilot or laptop, so hope not to mess anythgin up
mine are at 2.5k @24db. thats about as a low as I would want to run a tweeter. Sounds great to me, i tried 2k on the tweeters im using now but it doesnt sound good
bamaboy
War Eagle!!!
bamaboy
Auburn, Alabama
Here-I-Come
