Got my Amp now I need...
tryan77
your advice to make sure I install and set it up properly.
1) Alpine CDA-9887 Head Unit
1) Crunch p900.4 Amplifier
PowerZone Series 4-Channel AB Car Amplifier
Peak (Dynamic) Power Rating:
4 ohms: 115 watts x 4 chan.
2 ohms: 225 watts x 4 chan.
MOSFET power supply
Tuned Bass EQ (0-12 dB bass boost at 45 Hz)
Variable high-pass filter (60-1200 Hz, 24 dB/octave)
Variable low-pass filter (30-250 Hz, 24 dB/octave)
Variable input level control: 0.2V-5.0V
Frequency response: 30-1,200 Hz
Dimensions: 11.81"L x 10"W x 2.16"H
4) Infinity 6" x 8" Reference Series 2-way Speakers
Power Handling:
Peak: 360 watts per pair / 180 watts each
RMS: 120 watts per pair / 60 watts each
1-3/4" Edge-driven textile dome tweeters
Tweeter level adjustment (0 dB, 3 dB)
4 ohms impedance
Will be wiring it 4 Channel Full Range
A) Do I want to use the crossovers on the HU and set the crossovers on the amp to full?
B) It will then be set up to run at 2ohms? With the speakers being 4ohms does that matter?
C) Where would be a good ground source if the AMP is installed towards the back of the vehicle?
D) How would I properly mount the AMP to the floor? Do I drill directly into the floor?
Will be wiring it 4 Channel Full RangeA) Do I want to use the crossovers on the HU and set the crossovers on the amp to full?
You can invoke the high pass filter on the deck if you so choose to OR run it active. Since you didn't purchase component speakers, I suggest using the built-in High Pass filter on the Alpine.
If the amp can run 4 ohms stereo on two channels it will not have any problems running 2 ohms on the other channels since it is 2 ohm stable. Word of caution, those Infinity Reference speakers are NOT true 2 ohm drivers because they are guaranteed to work with any 4 ohm setup!
Wherever you can find a nice, shiny, clean, paint free metal surface close to your amps. It would help if that metal was close to a frame rail, but it isn't always necessary.
D) How would I properly mount the AMP to the floor? Do I drill directly into the floor?[/color]
I would take great pains to NOT mount the amp directly to any sheet metal. Doing so makes it a magnet for outside generated noise to make its way into your system. I have seen instances where isolating the mounting screws/bolts from the amplifier and vehicle metal has cleaned up noise.
Much thanks on the quick feedback - is there somewhere you can forward me to that would explain how to properly mount an amplifier so I can read up on it?
This isnt the first time youve helped me out so thanks a ton gunz. Its guys like you that make this forum great for noobies such as myself.
tryan77
tryan77
Milwaukee
tryan77
