got an amp what sub?
icwe2
10
LA
Soundstorm Sta212 Stealth Mosfet Power Amplifiers (2-channel, 1200 Watts)
* TRI-MODE OPERATION
* BRIDGEABLE
* 2_ STEREO STABLE
* FREQ RESP: 9 HZ50 HZ (3 DB)
* VARIABLE LOW-PASS CROSSOVER: 40 HZ150 HZ
* FIXED HIGH-PASS CROSSOVER: 200 HZ
* VARIABLE BASS BOOST: 0 DB18 DB
* POWER & PROTECTION LED INDICATORS
* ILLUMINATED RED LOGO
* THERMAL, OVERLOAD & SPEAKER SHORT PROTECTION
* LINE & SPEAKER LEVEL INPUTS
* CHROME-PLATED RCA CONNECTORS & TERMINAL SCREWS
* REMOTE SUBWOOFER LEVEL CONTROL
* 600W X 2 MAX @ 2_
* 230W X 2 RMS @ 2_
* 1200W X 1 BRIDGED @ 4_
* DIM: 11L X 11.25W X 3H
not sure if its any good but I got it close to nothing //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif maybe thats why cuz it sucks Im not sure but I was wondering if its any good and how big of wiring ill have to get in my car to push this amp. Right now I have 800 watt rockford wiring would that be enough maybe if i added a capacitor. If I need new wirign I can get that any suggestions for good sub that would be good for this amp?
http://www.stootsi.com/store/item.aspx?item=21182180
No need for a capacitor, they are useless in most applications, I doubt that amp will put out any more than 400rms so I would look for a single 4 ohm or dual 2 ohm driver that can take 400rms. First thing that comes to mind is a Kicker CVR.
you need subs that are rated for 230 watt rms and are 2 ohm or 8 ohm.
is that the rms rating on the rockford? if so the rockford will push more power
What? What Rockford? His wiring is rockford, and even if he also had a rockford amp that did 230rms how would it push more power than the other amp? One watt from one company isn't more powerful than a watt from another company.
no need to be a jerk i thought he had an rockford 800 watt amp im reading post to fast.
at least 4 gauge wiring and a dual 2-4ohm sub that can handle 4-600rms.
memphis power reference or m1
alphasonik psw 600-800series
kicker comps/cvr
boston
blaupunkt,ect.
really depends on budget.
Wiring will be fine, no need for a capacitor. I would consider a pair of Fusion Encounter subs, or a pair of Powerbass PS 12s those would do you fine.
icwe2
icwe2
LA
thaster
michigan born
    May 14, 2026
michigan born
    May 14, 2026
