After reading through the misinformation in the first few posts, I gave up.
Here is the truth:
1. LED is inferior to plasma in nearly every way and usually costs 1.5-2x as much.
2. Plasma life is longer than both LED and LCD
3. Plasma has better picture quality, faster response time, better viewing angles than both LCD and LED
4. As mentioned above... black levels on LEDs are approaching plasma... still not there. Again, substandard technology, higher price.
5. Plasma "burn-in" is all but a thing of the past, unless you're a complete ****ing dumbass or buy the cheapest, shittiest plasma out there and abuse it daily. Think of a Pyramid amp running with maxxed gains all day long.
Only two areas where LED/LCD even compare to plasma:
- power usage (plasma is only slightly higher, despite the deliberate misinformation you may have read)
- brightness levels - only a factor in VERY bright rooms with no way to control lighting at all. 95%+ of home environments it won't be an issue
These are the things I learned in the 4 months of research I did on HDTVs before buying my 54" Panasonic G10 plasma.
Misinformation is out there... research is your friend.
Here is the truth:
