got a question for the pros
yea i know there cheap but i got it for free an wat i mean is that wen its turned on right wen it gets power it blows both fuses that it has on it so i was wondering if it could be fixed so i can sell it and get some money off it
Have you checked your ground point??May not be a solid ground.. blowing the fuses???It sounds fixable.If you can take the cover off, maybe you can locate the issue if its not a bad ground point.If you know how to solder,maybe you can repair it?Getting it repaired may not be worth the trouble,and you may not come out ahead.You can take the amp to the car battery and test it there with the remote and power connected together,and then ground it,if it doesnt blow a fuse there then you have a bad ground connection,if it does, then the issue is internal.Worth a try??Used Boss amps arent worth much though,
LA951
LA951
Floresville, Texas, United States
LA951
