got a problem
r1dermon
ok, i want to use all infinity speakers for my system, because i can get them really cheap, anyway, im using the kappa perfect comps for my front, and i was gonna use the kappa 6x9's for the rear, both amped off of a 4 channel infinity amp giving 111x4@4ohms. this is a problem because, while the components are rated at 4ohms, the coaxial 6x9's are rated at 2ohms...i want rear fill, but i dont want to blow my amp out. any suggestions?
Most on these forums would advise you to bridge your amp to 2 channels and run it to your components and run the 6x9's off of the head unit. You are going to want most of your music up front with you. I would give that a try first and see how you like it. If not trade those 6x9's for some 4ohms and wire each channel to a speaker. you are not giong to want to give the rear speakers more power than the front.
r1dermon
r1dermon
Northern Massachusetts
r1dermon
