Got a new HT sub... Box?
galacticmonkey
Wants a button like that.
What about port area? Do HT boxes need more port?
Because I had a bandpass with a 12 in it that I built and in the car it JAMMED... In my room though it was still loud but I got a bunch of port noise, where there was none in a car.
looking at all the ht subs that come with a box.. even 15s etc they don't seem to need much port area.. it should fire back or down though.. and placement makes a ht sub Idk if you know that.. so you need to find the best place to put it after you build a box.. throwing in one spot will not do.. even if the first spot sounds good move it around.. along with the lpf and power.. you will be tweaking that for a few days of playing..
with only 300w you don't need all that port area.
A single 6" would be adequate.
Even at 500w with a single 6" you should not run any risk of port noise until you get to 20hz at full power.
with only 300w you don't need all that port area.A single 6" would be adequate.
x2, and with a 6ft^3 box tuned to 20hz you'll need that port to be ~28" long anyways...a pair will need to be 50" long each in the 7ft^3 @ 20hz box.
galacticmonkey
galacticmonkey
Tampa, FL
RAM_Designs
