Sold Got 4 amps, make some offers
dragnix
LXIX
here are the amps i need to get rid of so i can start a new system. Prices are neg. but please don't lowball me.
1st off: Orion HCCA225, missing speaker plugs //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif asking 180shipped
Output Power at 12.5V:
2 x 25W @ 4 ohms
2 x 50W @ 2 ohms
2 x 100W @ 1 ohm
2 x 200W @ ½ ohm
1 x 100W @ 4 ohms bridged
1 x 200W @ 2 ohms bridged
1 x 400W @ 1 ohm bridged
THD: 0.03%
S/N Ratio: 110dB
Fuse: External 35A
Freq. Response: 6Hz ∼ 20kHz (±0.5dB)
Dimensions: 11" x 8.5" x 2.25" (28cm x 21.6cm x 5.7cm)
Next, US Amps IS2100, asking 115shipped
Power: 100wx2 @ 4 165wx2 @ 2 330wx1 @ 4
S/N Ratio: 103dB
THD: >.01%
Channel Separation: 52dB
Damping Factor (@14.4v): 110
Crossover: HP 65hz-4.5khz LP 40hz-460khz
Protection: Reverse Polarity, Thermal, Short Circuit
Fuse Rating: 20Ax2
Size (LxWxH): 11 x 9.5 x 2.5
old date...i know
Autotek sx2300, asking 150shipped
250 Watts X 2 Channels @ 4 Ohms
350 Watts X 2 Channels @ 2 Ohms
450 Watts X 2 Channels @ 1 Ohm
700 Watts X 1 Channel @ 4 Ohms Bridged
800 Watts X 1 @ 2 Ohms Bridged
Remote Included
Full MOSFET Circuitry
Fully Adjustable X/Over
Regulated Power Supply
True 2 Ohm MONO
0-18 dB Variable Bass Boost @ 45Hz
Adjustable Line Outputs
4-AWG Molded Terminals
Chrome-Finish Heatsink
Chromed Front & End Panels
Maxi Fuse
Lastly, RF BD500.1, 140shipped
500watts@2ohm...i don't know much more than that
im thinking about the HCCA, any problems with it?
see post above //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Do you have paypal...I may take that Auto tek...I have dial up and am waiting on the pic to load...lol
paypal is dragnix85@yahoo.com //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The colors match on the inside of the amp so making a plug with loose bullet connectors is pretty easy once you see the other side. FYI. The only issue is that it usually has to be epoxy'd in since it vibrates a lot. Cosmetically it isn't pretty, but it works. You might help the sale by going ahead with the bullet connectors and labeling them (just be careful since everything will be backwards looking at it from the other side of the plug!).
That way you can sell it ready to install. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif With the stock plug (if you can find one) for around $45, or the option of having to basically glue the outputs, I'll sit on this one for a bit and see how it rides out.
Good luck on it, and I'd try to get it ready to go with the bullets for a quicker sale //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Got another question. This appears to be an earlier generation HCCA. I don't see this one having the removable center/top cover to access the crossover module. Is this correct? (gotta get all this straight before I can decide //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif )
Yes, that is correct //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I'll take this to the top for ya. . .
Thanks mang //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
dragnix
LXIX
dragnix
Socal cuz i'm So cool
Decado2
Mike Mccabe
