Good sq 8 maybe 10
explorer2
I need a very good sq 8 in sub, or a 10 if it is shallow enough and will perform well in a small box (~.5-.75 cu. ft.) I'll be getting a good amp to power it, and it will go with my current arc 4 channel, diamond speakers, and kenwood excelon hu. Whats a good choice?
How shallow? RL-i is a great choice...IDQ 8 if you can find one...Crystal CMP are supposed to be good but arent very loud unless your sending them upwards of 500 watts....
Might work, although that would leave little to no space behind the coil. I would prefer to be around 5-5.5" deep, but if I have to I will modify things.
Do it...just make the baffle a little thicker, or invert the sub //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif the RL-i would make a solid choice for a single sub setup...
However I am doing a single AA assassin in my bros car, I can give you results in a couple days...Box is already made, just awaiting the amp...
this is my RLi 8 in a factory box.. i just pulled off the grill and inverted it because i didnt have even 6" //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
It sounds amazing and has great output for a single 8" in a small box.
Thanks, I'd like to hear about the assasin. I'd rather not go inverted but I might be able to gain some room with an elevated trim ring instead of a flush grille.
Assassin 8s sound great in small sealed boxes...sometimes I miss the punchiness they had when I was running my four sealed...they can easily handle over 400 watts sealed...
Holy crap. What kind of amp were you running those 8's @ 400w each with if I may ask?
how well did 4 assasin 8s do? What size box? How loud? how low ect //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Ampman Audio 1500.1...Its underrated so somehere between 1500 and 1600...or 375-400 each....it was pretty loud...It was in about 2 cubes total sealed...then they were in 2.8 cubes ported tuned to 35...should have gone bigger //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
As far as low, nothing amazing, but they werent that bad at all...Songs like soul survivor shook my steering wheel in the second box....
explorer2
explorer2
usa
Fast1one
