Originally posted by grizzjwill I havent seen a second hand W7 for less than 400 dollars
I believe a W7 might be able to take it, as well as RF, so long as you don't seal them. Feels weird saying W7 and RF at the same line...
SO long as one is careful with the gains, I'm sure both subs can handle a bit more power than its initial rating. Also depends, really.
W7's are 4ohm SVC.
The RF punch series HX2 is 4ohm DVC(final = 2 ohms) .
The RF power HX2, on the other hand, is 2ohm DVC (final = 1 or 4ohms) .
All in all, I say as far as power goes, both subs would have no problems with a little over the recommended.
If your amp puts out about 750w RMS @ 4ohms, I think that's too bad, pushing either sub. Only difference is how clean or brutal you want the bass whipping on your back.
If I'm not mistaken, MTX amps are not known as an SQ amp. (According to knowledgable people on the forum, there IS such a thing as an SQ amp)
