good match speakers to amp?
KJThaDon
I am getting these speakers for my interior but would like to know if the amp is a good match?
I want to stick with a kicker amp etc, so what do you think?
Also how would I wire these all together, would it be basically like this?
Code:
http://m.seimg.net/product/img/subwoofer_wiring/4_subs_SVC_4_ohm_4ch.jpg
2 x Rear 6x9's (11KS693) 100 RMS ea. - 4 OHM
Code:
 http://www.onlinecarstereo.com/CarAudio/p_28129_Kicker_KS693.aspx
2 x Door 5.25 (11KS525) 45 RMS ea. - 4OHM
Code:
http://www.onlinecarstereo.com/CarAudio/p_28122_Kicker_KS525.aspx
1 x Amplifier (11ZX350.4)
350 RMS 4 CH
60W RMS x 4-Channel @ 4 Ohms
90W RMS x 4-Channel @ 2 Ohms
Code:
http://www.onlinecarstereo.com/CarAudio/p_27999_Kicker_ZX3504.aspx
Thank you!
follow the installation instructions that comes with the kicker amp. one speaker per amp channel. you can download the manual for free ahead of time. yes, that diagram is accurate.
the tricky part is actuall making connections that are secure and not a hazard to short out. as a general rule, if you can see bare copper wire, the connection is no good. fully insulate connections - at speakers use female disconnects with an insulated cover. at the amp use spade terminals (if applicable). will require a good crimper.
KJThaDon
KJThaDon
Westland. Michigan
keep_hope_alive
